[Sc...] Posted October 20, 2022 Share Posted October 20, 2022 Hello So I am creating a program for a shaft with a long bore thru hole (300+mm). My issue is the because of size constraints in the Y axis I have to mount so it can be measured in the Z axis but I need to be able to rotate the part 180° to get to the other end to measure the balance of the characteristics. How do I do this and keep all of the base alignment information, like the part axis for runout or do I just create 2 separate programs to get all of the required measurements ? Thanks ! Link to comment https://qualityforum.zeiss.com/topic/9352-program-with-180%C2%B0-part-rotation-rotation/ Share on other sites More sharing options...
[Ma...] Posted October 20, 2022 Share Posted October 20, 2022 Does your characteristics need features from both sides? If not, then you can make second part just by rotating model and using condition with prompt to continue program. If yes, then there is alignment to fit and join both sides ( i have little icon of airplane ). If you have FF on it, then it can be tricky. Link to comment https://qualityforum.zeiss.com/topic/9352-program-with-180%C2%B0-part-rotation-rotation/#findComment-43338 Share on other sites More sharing options...
