Contura XT Vast 10/16/6 Multi Rack help
Hello,
I am trying to find a multi level Probe rack to use for my Contura. Currently we have a Single T stand with 5 Bays. I need way 5 More Bays.
Attached is the only one i can find but it says 700MM High. I think that's to high for my machine. Does anyone know where I can find one if this isn't the correct rack.
I posted in the Hardware section as well, but that section looks deserted.
Thanks.
SO, my height is fine, its roughly 27" which has still plenty of space. Are all multi lvl racks spaced to fit the bolt holes on the Granite of the CMM in X. 1000mm comes to 39" roughly. However it mentions 1100mm , which is 43" and i not sure will fit. I am probably over complicating this but I just don't want to be wrong and have to return it if it doesn't fit.
Silvio, if you go to the webshop - there is a chat now button, they can assist you in getting the correct part.
Thanks.
I did, they told me to talk to Tech Support lol. I am just going to go ahead and order the original one in my attachment. I think I will be fine. Thanks all for the responses.
I believe we have the same one on our Contura.
Bolt holes line up and you can get at least 5 standard holders on each level.
