[Si...] Posted October 14, 2022 Share Posted October 14, 2022 Hello, I am trying to find a multi level Probe rack to use for my Contura. Currently we have a Single T stand with 5 Bays. I need way 5 More Bays. Attached is the only one i can find but it says 700MM High. I think that's to high for my machine. Does anyone know where I can find one if this isn't the correct rack. I posted in the Hardware section as well, but that section looks deserted. Thanks.Multi Rack Contura.png Link to comment Share on other sites More sharing options...
[To...] Posted October 14, 2022 Share Posted October 14, 2022 Maybe this one? https://shop.metrology.zeiss.com/INTERS ... gID=400000 Link to comment Share on other sites More sharing options...
[Ri...] Posted October 14, 2022 Share Posted October 14, 2022 I would contact your sales rep, but per Simulation, this would be the rack you would want. https://shop.metrology.zeiss.com/INTERS ... gID=400000 Like I said, I would contact your rep to ensure that it will work on your machine, but "it should". Thanks. Link to comment Share on other sites More sharing options...
[Si...] Posted October 14, 2022 Author Share Posted October 14, 2022 SO, my height is fine, its roughly 27" which has still plenty of space. Are all multi lvl racks spaced to fit the bolt holes on the Granite of the CMM in X. 1000mm comes to 39" roughly. However it mentions 1100mm , which is 43" and i not sure will fit. I am probably over complicating this but I just don't want to be wrong and have to return it if it doesn't fit. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 14, 2022 Share Posted October 14, 2022 Please sign in to view this quote. Silvio, if you go to the webshop - there is a chat now button, they can assist you in getting the correct part. Thanks. Link to comment Share on other sites More sharing options...
[Si...] Posted October 14, 2022 Author Share Posted October 14, 2022 I did, they told me to talk to Tech Support lol. I am just going to go ahead and order the original one in my attachment. I think I will be fine. Thanks all for the responses. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 17, 2022 Share Posted October 17, 2022 Please sign in to view this quote. I believe we have the same one on our Contura. Bolt holes line up and you can get at least 5 standard holders on each level. Link to comment Share on other sites More sharing options...
[To...] Posted October 19, 2022 Share Posted October 19, 2022 Please sign in to view this quote. FYI Several models of the new Contura have an 800mm Z, so I wouldn't just assume that it will fit. https://shop.metrology.zeiss.com/INTERS ... m:msr+1000MSR 1000.JPG Link to comment Share on other sites More sharing options...
