[Pa...] Posted September 24, 2021 Share Posted September 24, 2021 Hallo, ich habe einen längeren Sterntaster bestellt und zusammengesetzt, stelle fest, dass XXT TL3 auf unseren TL1 ja gar nicht kompatibel ist. Einen Messkopf TL3 gibt es auch nicht im Shop. Zunächst würde ich aber gerne wissen, ob denn die Messteller TL1 auf einen TL3 abwärtskompatibel wären. Danke. Link to comment Share on other sites More sharing options...
[To...] Posted September 24, 2021 Share Posted September 24, 2021 Please sign in to view this quote. The balls on the adapter plate are in a different configuration between the TL1 and TL3. They are not interchangeable. You say it is not available.... Do you mean "not in stock"? https://shop.metrology.zeiss.com/INTERS ... gID=300000 Link to comment Share on other sites More sharing options...
[Pa...] Posted September 25, 2021 Author Share Posted September 25, 2021 Hi, I didn't find it at German Shop to buy. I found it at Shop in Switzerland online, but needed to live there. Your link is not working for me. I need a 75 mm star plate for TL1 then, but there is only TL3 available. Because compability is not available, this would be the best solution. Link to comment Share on other sites More sharing options...
[To...] Posted September 25, 2021 Share Posted September 25, 2021 Please sign in to view this quote. Sorry. I misunderstood your post. Link to comment Share on other sites More sharing options...
[Fa...] Posted October 19, 2022 Share Posted October 19, 2022 einfach einen Tasterteller TL1 bestellen, du brauchst nicht gleich den ganzen Messkopf tauschen. auf diesem Tasterteller kannst du deinen Sterntaster wieder aufbauen Link to comment Share on other sites More sharing options...
