SSC to PCF file convert
I was sent a program to try out and there were no stylus system pcf files in the probe cal, just ssc files in a separate folder. Can these ssc files be converted and then imported onto a live machine?
Thanks
It looks as though planner on my pc box is an option we didn't didn't purchase. It's grey shaded/no click at the top even when I connect to simulation. 🙁
On the newer versions you can have the menu to the left of it highlighted, and then slide the mouse over and it will allow you to select it.
