[Fl...] Posted September 28, 2022 Share Posted September 28, 2022 How i should report surface profile - not line profile? So more curves into one surface. I don't know (i make the curve, the general surface and how? ). I attached the photos with the drw. request. drw req.JPGFetching info... Link to comment Share on other sites More sharing options...
[Cl...] Posted September 28, 2022 Share Posted September 28, 2022 I usually do one of two things. Either scan multiple 3d curves, recalling them into a Freeform Surface, or I go to: CAD - Creating features - Point Set - Freeform Surface From face(s). Does that help? Link to comment Share on other sites More sharing options...
[Fl...] Posted September 29, 2022 Author Share Posted September 29, 2022 Thank's for answer but i have a problem. I don't have freeform options available. Is possible with general surface or another method? Link to comment Share on other sites More sharing options...
[Cl...] Posted September 29, 2022 Share Posted September 29, 2022 I got this off the forum a while back, should help with your problem. Link to comment Share on other sites More sharing options...
[To...] Posted September 30, 2022 Share Posted September 30, 2022 Please sign in to view this quote. This document states that this only works if you have a fully constrained DRF Link to comment Share on other sites More sharing options...
[Ia...] Posted October 4, 2022 Share Posted October 4, 2022 Please sign in to view this quote. What if you made a best fit alignment, and made all your space points aligned to that? Just curious. Link to comment Share on other sites More sharing options...
[To...] Posted October 4, 2022 Share Posted October 4, 2022 Please sign in to view this quote. I believe that is a common workaround. Link to comment Share on other sites More sharing options...
[Fl...] Posted October 5, 2022 Author Share Posted October 5, 2022 Thank you all for the replies, but I haven't received anything relevant. I am telling my method, how I proceed, and if I am wrong somewhere, please correct me: 1) I do a scan with 2 d lines 2) I evaluate this scan (features) with line profile and best fit 3) because I need to choose something in the features box (line profile, see picture). now I chose linear projection,,best fit, and in the box with Evaluation (see photos) for stylus radius correction I chose nom. Spline. is OK? Do I need to change something, check something? Thank's 20221005_094542.jpgFetching info... 20221005_094531.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ma...] Posted October 5, 2022 Share Posted October 5, 2022 I would sugest make more of 2D/3D curves ( 3D if it is rotary part ) then from Resources -> Utilities -> Alignment from Several Curves - select all curves, set options ( translate, num. of points used ) then report general surface to this alignment. Link to comment Share on other sites More sharing options...
[Fl...] Posted October 5, 2022 Author Share Posted October 5, 2022 thanks for answer. I did but I can't find it: set options ( translate, num. of points used ) then report general surface to this alignment. thanks in advance Link to comment Share on other sites More sharing options...
[Ma...] Posted October 5, 2022 Share Posted October 5, 2022 Here is screenshot from pdf manual of Calypso 2021 Link to comment Share on other sites More sharing options...
