Info on the run screen in Autorun?
During a Calypso run if a problem occurs the user can be presented with an "Info on the run" screen that describes the problem and allows the problem to be reset. (For example...not enough points for feature calculation). Is there any way to allow the "Info on the run" screen to be presented to users if the Autorun screen is being used?
Info on Run can be included in the printout. Reseting Autorun would be a nice feature. As far as I know it is not possible.
If not enough points error occurs, the program should be improved. using alignments to "find" other features is normally what I do. Sometimes a Features "Measure Reference" can be used.
