[Ar...] Posted September 28, 2022 Share Posted September 28, 2022 Hello Calypso users, I need your help to understand a problem I have while importing a stylus from an .SSC file. I have created a stylus with Zeiss Stylus Creator and save it as an .SST, its data or the following For whatever reason, when I import the file to Calypso, the coordinates/vectors of the stylus are completely different, as if a rotation had occurred.... I suspect some error with the master probe, it's vectorial coordinates are X=0 Y=1 Z=0 but i cannot change those values (I should have Z=1 and 1 and Y=0?) I can still correct the data manually but I would prefer not do so. Thanks a lot if someone knows why Arthur Link to comment https://qualityforum.zeiss.com/topic/9496-error-when-importing-an-ssc-stylus/ Share on other sites More sharing options...
