Error when importing an SSC stylus
Hello Calypso users,
I need your help to understand a problem I have while importing a stylus from an .SSC file.
I have created a stylus with Zeiss Stylus Creator and save it as an .SST, its data or the following 5310_e238b81264c33b6464bbd8ef4931ea9c.png
For whatever reason, when I import the file to Calypso, the coordinates/vectors of the stylus are completely different, as if a rotation had occurred.... 5310_b98a184b567155f3a6805ae14fd982ac.png
I suspect some error with the master probe, it's vectorial coordinates are X=0 Y=1 Z=0 but i cannot change those values (I should have Z=1 and 1 and Y=0?) 5310_8962b269b4398204e6ad9cd393006b89.png
I can still correct the data manually but I would prefer not do so.
Thanks a lot if someone knows why
Arthur
https://qualityforum.zeiss.com/topic/9496-error-when-importing-an-ssc-stylus/
