[Ja...] Posted April 3, 2018 Share Posted April 3, 2018 Hi All. I've learned almost all I know from the good people here. Thank You. Today I tried to delete a single run/data set from the PiWeb database and when I select the Recourses > Results to file > PiWeb Reporting > Configuration > Managing measurements, nothing happens. The help file says: Managing measurements - Displays measurements in PiWeb reporting and allows deleting individual ones. I was logged in as Master. Maybe this feature is only available with the plus option ? I have been using the Table template for small runs because it is easy to see part to part problems but would like the option to remove a measurement once in a while. I have had luck deleting the whole database *.dfm file but would rather not do that. TIA Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/ Share on other sites More sharing options...
[Mi...] Posted April 5, 2018 Share Posted April 5, 2018 Yes you can delete single measurements. Open the PiWeb monitor and click the drop down box that the arrow points too. In the drop down go to EDIT MEASUREMENT and you will see the second pop up window as pictured. Then click to open the individual measurements. From here you can delete one at a time etc...2.JPG Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/#findComment-44368 Share on other sites More sharing options...
[3c...] Posted April 5, 2018 Share Posted April 5, 2018 I've seen the 'Managing Measurements' screen not pop up when a program has been 'Saved as...' a new name. Is that the case with the program you're working on now? Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/#findComment-44370 Share on other sites More sharing options...
[Ja...] Posted April 5, 2018 Author Share Posted April 5, 2018 Thanks Mike. That works. Laura, I did 'save as' a few times as I was building the program. I also deleted the actual database file too after a few set up runs. I'll have to try the 'Managing Measurements' again with a new program. Thank you. Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/#findComment-44372 Share on other sites More sharing options...
[Mi...] Posted April 26, 2018 Share Posted April 26, 2018 Nice.. I also use that feature if the CMM shows something out, and I manually re check it I can go in and change the results. I do this at times for like ID's after I pin them with Deltronic pins etc.. Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/#findComment-44374 Share on other sites More sharing options...
[Ja...] Posted September 15, 2022 Share Posted September 15, 2022 Please sign in to view this quote. What if the "Edit Measurement..." button is grayed out? Is there a way to turn this option ON and OFF? I'm using PiWeb Reporting Plus version 7.8.10. Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/#findComment-44376 Share on other sites More sharing options...
[Gu...] Posted September 22, 2022 Share Posted September 22, 2022 Easiest method: Use the "Block"/"Accepted" button in the "AcceptProtocol.ptx" or "StandardProtocol.ptx". "Block" button locks the selected measurement in the database. All CALYPSO standard reports have a measurement filter "Measurement is not blocked" as default If necessary, the filter can be adjusted Link to comment https://qualityforum.zeiss.com/topic/9520-piweb-reporting-database-question/#findComment-44378 Share on other sites More sharing options...
