[Ri...] Posted September 16, 2022 Share Posted September 16, 2022 I'm not familiar with this particular designation. "Tolerance Principle" Any help is appreciated.Capture.JPG Link to comment Share on other sites More sharing options...
[Ma...] Posted September 16, 2022 Share Posted September 16, 2022 I have no clue - usualy it will be capital letter i or number 1. I found only mentions about number of decimal places - aka in tenths ( 0,1mm ) but i am not sure. I would ignore it 🤣 Link to comment Share on other sites More sharing options...
[Da...] Posted September 16, 2022 Share Posted September 16, 2022 That’s the symbol for the Independency Principle, which is odd, because in ISO it’s the default anyway. I’m not even sure if this symbol exists in ISO. So basically it means: Don’t use the Rule #1 from ASME. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 21, 2022 Author Share Posted September 21, 2022 Thanks for the information. Adding this info so others can see the answer. Please sign in to view this quote. See attached pdf file.Rule #1 is referred to as the -Individual Feature of Size Rule.pdf Link to comment Share on other sites More sharing options...
