2022 Calypso ?
Hard to get past the new icons. A lot don't even make sense if you have been using the software for awhile.
As for bugs, the only one that I've noticed is that if you create a FFS that recalls feature points, associate the surfaces before you recall feature points other wise it will be extremely slow at first.
There are still a lot of features that were promised that I have yet to see - mainly around GD&T, so that is the biggest disappointment for me.
https://qualityforum.zeiss.com/topic/9562-2022-calypso/#findComment-44570
With regards to the icons,
There is a place on the Zeiss portal called "My-Voice" where users can suggest things they would like to see fixed, changed, or added to Calypso, and vote on other users posts in order to increase their visibility to Zeiss. Here are two suggestions regarding the icons in 2022.
https://portal.zeiss.com/my-voice/softw ... 79a8da8ad3
https://portal.zeiss.com/my-voice/softw ... 6141fb9a4f
https://qualityforum.zeiss.com/topic/9562-2022-calypso/#findComment-44572
