[Ri...] Posted September 12, 2022 Share Posted September 12, 2022 I've used it... Never questioned the tolerance as a value. (working in Inch mode) Assuming a 90° angularity, what does the tolerance represent? Example: Is a .010 tolerance an inch value? Radian value? Degrees? Link to comment Share on other sites More sharing options...
[Ju...] Posted September 12, 2022 Share Posted September 12, 2022 The given tolerance means that at the specified angle axis (90°), the axes of all features involved have to fit inside the tolerance zone, which in your case, would be 0.010" from either nominal feature axis.Angularity.jpg Link to comment Share on other sites More sharing options...
[Ri...] Posted September 12, 2022 Share Posted September 12, 2022 Angularity is the exact same calculation as Perpendicularity. The only difference is that Perpendicularity sets the nominal angle to 90°. Angularity allows for any angle to be the nominal angle. Link to comment Share on other sites More sharing options...
[To...] Posted September 12, 2022 Share Posted September 12, 2022 Please sign in to view this quote. Don't forget Parallelism is in the same category where the nominal angle is 0° Link to comment Share on other sites More sharing options...
[Ri...] Posted September 12, 2022 Share Posted September 12, 2022 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
