[Ri...] Posted September 8, 2022 Share Posted September 8, 2022 Are there SQL issues running an older version of Calypso (v6.08.x) and a Current version of Calypso (v7.2.12)? I need to have an older version for customers who run, well, older versions. Link to comment Share on other sites More sharing options...
[Mi...] Posted September 8, 2022 Share Posted September 8, 2022 I currently have 8 Calypso versions on my PC. These are Planner seats but I have everything from 4.0 to 7.something and there's no problems with any of them. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 8, 2022 Author Share Posted September 8, 2022 I'm having some issue with SQL files. The attached zip file has screen shots of error dialog boxes. (I finally found them)Fw__Installing_Calypso_v6.0.08_(Older_version).zip Link to comment Share on other sites More sharing options...
[Ri...] Posted September 8, 2022 Share Posted September 8, 2022 I would always recommend installing in order. I have had a lot of issues installing an older version after newer versions have been installed. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 8, 2022 Author Share Posted September 8, 2022 Please sign in to view this quote. I just learned this. There is definitely an issue with the SQL installation going from new to older version. I'm skipping the side by side install and going with a sperate PC for the v6.x Calypso using KVM switches. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 8, 2022 Share Posted September 8, 2022 Please sign in to view this quote. Yeah - what ends up happening is that they try to share the same Users/Documents/ folder and that is where the issues begin. Link to comment Share on other sites More sharing options...
[No...] Posted September 9, 2022 Share Posted September 9, 2022 I never had direct issues (read: error messages) with parallel installations, but I also never installed an older version after a newer one. I had issues in 6.6 however after I installed 7.2. The first was that the Calypso backup function started to fail in 6.6. It probably was because they changed the way Calypso interacts with SQL server, which caused a small background tool, which ensures the 6.6 probe database is detached from the server before backup, crashed, and the probe database was missing from the backup. Another issue was that the 6.6 simulation on my offline seat didn't show the probes anymore. Probably this was connected to the other issue. In general, the last Calypso version installed sets an environment variable pointing to its own \users\public\documents\ folder. Some functions (like the PiWeb template setting) take their default path from this variable, but this can be overridden by setting a different one. Link to comment Share on other sites More sharing options...
