[Da...] Posted April 21, 2022 Share Posted April 21, 2022 How long is an accreditation certificate good for??? Ours says it was 26.08.2020 Is it still valid ? Where can I find copies? Link to comment https://qualityforum.zeiss.com/topic/9634-accreditation-docs/ Share on other sites More sharing options...
[De...] Posted September 6, 2022 Share Posted September 6, 2022 A lot depends on your companies policies. The cert is only the condition of the machine at the time the calibration is done. Once the tech leaves your facility they can't say that the machine is in spec because they do not have control of the machine once they leave. Most places I have worked for use annual calibrations for CMMs, but the intervals may be 6 months, annually, 3 months, whatever your company policies are. The argument to increase the frequency sometimes has to do to the tolerances you measure being very small and the conditions the machine operates in can cause issues. Also to decrease the frequency and go to 18 months or 2 years sometimes is driven by the data not really shifting much from calibration to calibration. To answer your question directly the cert is only good until the tech leaves. What your company accepts is a matter of your policies, but typically 1 year. Link to comment https://qualityforum.zeiss.com/topic/9634-accreditation-docs/#findComment-44972 Share on other sites More sharing options...
