Pallet in XZ
We have a fixture that was made in XZ. Autorun allows you offsets in XY. Is there a way to offset in Z for each row? Right now it executes the first row, moves to the second row and offsets towards you, alwomst like it thinks the fixture is stepped. Any thoughts?
I tested what I suggested and it does work.
Still shows X and Y in the pallet setup but with the pallet alignment set to +Y in the Z direction it makes sense.
It works as if you have the parts fixtured above each other. I'm guessing this is what you are trying to achieve?
