Getting more details in evaluation
You have to check "Display banners" - i don't use "Banners per page" so try to uncheck it and leave checked "Banner display for each ..."
Then you have to select deviation bar at the end of it ( start is from nominal ). Otherwise when you leave textbox empty, then it will show banners for all points.
Then of course it's always fun when you accidentally click an entire group instead of a single characteristic and your computer gets hit with a banner bomb.
This can be prevented by using "banners per page," but it isn't a default option, so I usually get thumped by a few banner bombs over the course of proving out a measurement plan.
