Erratic RDS
Contura G2 - RDS/XXT/TL1. Behaving oddly. It jerks when rotating, and sometimes
abruptly stops in the middle of a rotation and errors out. No collisions have occurred.
Your RDS could be bad. I've been told by a few Zeiss techs that the RDS is only good for so many rotations and then they will wear out. They gave a number of rotations but I can't remember what it was. My company has had to replace a few RDS on our Contura G2 and Spectrum when they started doing funny stuff like you're describing
I know that Zeiss quantified the RDS life by the number of rotations... but how long did yours last (how many years & running how many shifts?)
I have been told this as well.
Then Zeiss makes all these unnecessary articulations before and after every tool change... 🙄
And let's be honest, most of them are refurbished, tested, and then sent out again. I imagine these have less life than a new one. When ours wore out, they brought one in to be installed, and it wasn't working properly. They had to ship in another next day, to be installed.
You are totally correct. When one of our CMMs needed a new RDS, the replacement showed up with a very large gouge. The Zeiss tech installed it and did not pass his tests. He had to order another one.
Usually the Zeiss PO will be inflated in case there are other unforeseen issues
