[To...] Posted August 22, 2022 Share Posted August 22, 2022 Looking for ideas to get a good BA on this part. Part shifts approximately 1 part length in Y. Spatial: Top Plane Planar: Symmetry Const. (2 side planes 22.5° apart) X Origin: Symmetry Const. Y Origin: OD Z Origin: Top Plane What do you think about a 3D Best Fit alignment?Screenshot 2022-08-22 081113.jpg Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/ Share on other sites More sharing options...
[Ri...] Posted August 22, 2022 Share Posted August 22, 2022 I would always prefer to measure as a circle, so my first attempt would be to use a 2d-Curve, and allow it to Best-Fit in the X,Y (Translation), and the Z (Rotation). Tell it to create an alignment from that, and measure your 4-5 single point circle inside your Curve Best-Fit Alignment - constrain the location. You can also use Free-Form and create a Best-Fit Alignment as well, and measure multiple circle paths if you want. Good luck. Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/#findComment-45818 Share on other sites More sharing options...
[Ma...] Posted August 22, 2022 Share Posted August 22, 2022 I would just use only touch point for Y, you can get X nominal from symmetry using formula. Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/#findComment-45820 Share on other sites More sharing options...
[To...] Posted August 22, 2022 Author Share Posted August 22, 2022 Please sign in to view this quote. Is this done as part of BA? Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/#findComment-45822 Share on other sites More sharing options...
[Th...] Posted August 22, 2022 Share Posted August 22, 2022 Would a simple 3DBF with single points be adequate for alignment? Just slap a few points per surface on there. Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/#findComment-45824 Share on other sites More sharing options...
[Ri...] Posted August 22, 2022 Share Posted August 22, 2022 Please sign in to view this quote. You can, but I realized that I completely misread your post, so my apologies. Could you use an intersection from the two planes as the X,Y Origin, and then clock to one of the edges? But yes - a 3d best fit would work as well. Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/#findComment-45826 Share on other sites More sharing options...
[Ri...] Posted August 22, 2022 Share Posted August 22, 2022 If I'm reading the Ops post correctly... I would create an intersection at each of the four corners. Then create two Symmetry points at Y- and Y+ Project the symmetry points to the top plane. Create a 2d line from Y- to Y+. This gives a centerline and a tertiary. That's just for a base Alignment, which doesn't need to be ultra precise, you just need to define something exists in that portion of the volumetric area. Link to comment https://qualityforum.zeiss.com/topic/9734-another-short-arc-segment/#findComment-45828 Share on other sites More sharing options...
