[Th...] Posted August 15, 2022 Share Posted August 15, 2022 I think I've asked this before, but it's been a while, so here goes. Our current practice is to add curve forms to graphics elements. This allows me to set the elements to only display certain curve segments (since we have multiple measurement gaps in most of our curve features), and allows me to select the graphics element characteristics as part of a mini-plan. This means that only the curve forms that are evaluated in a mini-plan are displayed, and mini-plans with no curves do not create empty elements. With the 2022 update removing graphics element creation, I'm forced* to switch to Piweb templates to display profiles graphically. The closest I've been able to get to the old setup is to apply segmented tolerances in the feature, create a program-specific copy of the form plot template, create duplicate pages, and explicitly bind individual profile characteristics to the protocols and line profile entities. In this way, I can limit the Piweb elements per page to only one profile, which allows me to set the displayed segments for that profile within the template. If I just leave the template to handle all the profiles with one element like the generic template does, I get plots with graphs that include all the segments, including those I didn't actually scan and did not include in the profile evaluation. This is where the problem is. Because this is just a Piweb template, the whole thing is displayed regardless of how many of the profiles were actually measured, meaning random empty pages for reduced-inspection mini-plans. I can't select individual plots to show or not show like I could with graphics elements. Further, if I run a mini-plan that doesn't check any profiles, I'll get a plot protocol displayed that's completely empty. Is there some way for me to get the Piweb report to mimic the old method, and only output pages that have something to show? *I can work around the graphics element menu removal by copy/pasting elements from other programs and working with them like that, but this is a really silly and tedious way to avoid the problem. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 14, 2025 Share Posted October 14, 2025 I am having the same issue... any ideas on how to not have a page generated if no data? Link to comment Share on other sites More sharing options...
[Ri...] Posted October 14, 2025 Share Posted October 14, 2025 Please share your template, and I'll take a quick look. Also state what version of Calypso you are doing this in. 🙂 Link to comment Share on other sites More sharing options...
[Jo...] Posted October 14, 2025 Share Posted October 14, 2025 i cannot share, but its basically the standard zeiss template. I have the plot page not hidden, but put a filter on it to only show O.O.T features. Right now i am in version 8.2.5 Link to comment Share on other sites More sharing options...
[Ri...] Posted October 14, 2025 Share Posted October 14, 2025 Please sign in to view this username. Try this. In your Designer - goto View - Filter pages. Then in the By page status tab, select Pages with measured data. 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted October 14, 2025 Share Posted October 14, 2025 sorry that did not work... prints and creates pdf with blank pages...... Link to comment Share on other sites More sharing options...
[Ri...] Posted October 14, 2025 Share Posted October 14, 2025 (edited) Works with no issues for me. StandardProtocol2.zip Edited October 14, 2025 Link to comment Share on other sites More sharing options...
[Jo...] Posted October 14, 2025 Share Posted October 14, 2025 Weird... you must have something turned on that i do not... i noticed before you clicked.. it showed the extra page... but the pdf does not. I took yours and plugged into mine and before i clicked anywhere in the monitor... it showed total of 9 pages but printout and pdf shows 8. I have the page filter turn on just like yours but it does not work?? Link to comment Share on other sites More sharing options...
[Ri...] Posted October 14, 2025 Share Posted October 14, 2025 Yes - it will initially show the blank page, but when you tell it to refresh all pages (F7) it should show correctly. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 14, 2025 Share Posted October 14, 2025 i just got find out what is different between the two... Link to comment Share on other sites More sharing options...
[Jo...] Posted October 15, 2025 Share Posted October 15, 2025 ok... well I am very new to Piweb and the only reason why I have to even know anything about it, is because we are being forced to go to it. It is really not needed in my area or parts and a simple custom printout for the day to day inspectors is all that is needed..... that being said.... how did you get it to auto refresh and also only show what you ran? I know you can go in and filter by measurement data but that would we require the inspectors to do it manually and we (company) do not want them to do anything but run the machine, have the report auto print out and thats it... Link to comment Share on other sites More sharing options...
[Jo...] Posted October 15, 2025 Share Posted October 15, 2025 sorry for all the posts... just trying to figure this out... what i come up with is... its the header... i delete it and it works.... i keep it in and it does not work.... Link to comment Share on other sites More sharing options...
[Th...] Posted October 17, 2025 Author Share Posted October 17, 2025 Please sign in to view this quote. Stymied for three years by a setting I didn't know existed, and one that really seems like it should be the default program behavior. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 20, 2025 Share Posted October 20, 2025 problem was the header.... variables in header showing up as measured data so it was always printing a blank page no mater what... used a different variable and it works now Link to comment Share on other sites More sharing options...
