[Bl...] Posted August 12, 2022 Share Posted August 12, 2022 I am looking for a way to add an automatic stylus system change at the end of my program. I'm using two types of stylus systems and I would like for the CMM to change back to the first one while I put the next part in the fixture to save time. Is this possible? Link to comment https://qualityforum.zeiss.com/topic/9772-automatic-stylus-system-change-at-the-end-of-program-run/ Share on other sites More sharing options...
[Ma...] Posted August 12, 2022 Share Posted August 12, 2022 One way is you can use the End Park Position. Create New Select the Stylus system change icon and open it and select the system to change to I'm not sure that it is necessary to include a park position or if you can just use the Stylus system change. Park position will get it away from the rack and closer to your workpiece or wherever you set it. Link to comment https://qualityforum.zeiss.com/topic/9772-automatic-stylus-system-change-at-the-end-of-program-run/#findComment-46128 Share on other sites More sharing options...
[To...] Posted August 13, 2022 Share Posted August 13, 2022 The only downside is the program is not finished until the stylus system change is complete which means you have to wait to get your report. Link to comment https://qualityforum.zeiss.com/topic/9772-automatic-stylus-system-change-at-the-end-of-program-run/#findComment-46130 Share on other sites More sharing options...
[Ma...] Posted August 15, 2022 Share Posted August 15, 2022 I was kind of thinking the same thing. Either way it will still need to take the time to change stylus systems whether it is the beginning or end of the program. Link to comment https://qualityforum.zeiss.com/topic/9772-automatic-stylus-system-change-at-the-end-of-program-run/#findComment-46132 Share on other sites More sharing options...
