[Bl...] Posted August 10, 2022 Share Posted August 10, 2022 Recently there were some technical issues at my company and the settings I selected for Calypso 2019 (which were recommended in class) are back to default. Since I made these selections three years ago I cannot remember where to find them. The main issue I am noticing for Planes is the polylines do not automatically generate in the strategy. Also, I cannot change the angle range for a circle path strategy as the box is gray and set to 450. (i.e. I select a semicircle CAD feature and Calypso wants to measure a full circle.) If anyone remembers or has the notes for the recommended initial settings they received in class it would be very helpful. Link to comment Share on other sites More sharing options...
[Ma...] Posted August 11, 2022 Share Posted August 11, 2022 Don't know how planes, but for circles you have enabled tangential scanning. Link to comment Share on other sites More sharing options...
[No...] Posted August 11, 2022 Share Posted August 11, 2022 You may have had some strategy defaults saved (Resources -> Save/Load Defaults): Link to comment Share on other sites More sharing options...
[Bl...] Posted August 11, 2022 Author Share Posted August 11, 2022 Thank you very much for your help! Problem solved. 😃 Link to comment Share on other sites More sharing options...
