Base Alignment Match
Well, the pointer doc is not so clear. When I chose the bridge features, it says I will be prompted to manually measure those features but it did not.
So, i figured maybe it will have when I run the program. I ran the base alignment, some features on the first location. It stopped and prompted to measure my bridge features manually. Completed that but when it went to re-measure in cnc, it went somewhere else. Tried setting this up on 2 occasions with no success.
I'm sure it is something I am not doing correctly. If anyone has any helpful info on this, I'd appreciate it if you wouldn't mind posting it.
TIA
https://qualityforum.zeiss.com/topic/9806-base-alignment-match/#findComment-46352
  • 1 month later...
I create my programs to run from the features list so in order for the machine to know which alignment to use I have to go the Measurement plan editor features - Sequence after base alignment match. Then select those features and set to base alignment match for the machine to understand.
https://qualityforum.zeiss.com/topic/9806-base-alignment-match/#findComment-46362
