[Je...] Posted April 23, 2022 Share Posted April 23, 2022 Hello, I am trying to run a PCM script after every feature in any inspection. This is working fine through a "plugin_postFeature_pcm.txt" file inside a specific measurement plan directory. However, when I move this file to the default global inspection directory (workarea/inspections) it does not execute after every feature. In fact, it does not execute at all. To me, it seems like the "plugin_{pre/post}{Feature/Characteristic}_pcm.txt" files can not execute if they are not inside an actual measurement plan. Other PCM scripts (e.g. inspection_start_pcm.txt) do work from the global inspection directory, but aforementioned 4 specific files are never ran. This behaviour does not seem to be documented and I can not find any issue concerning this on the internet either. Does anyone have an idea of how to solve this issue, or a workaround? I would prefer not having to add the script to every individual measurement plan, we have hundreds of programs and the risk of having older/multiple versions of said script floating around is rather high. Kind regards, Jelle Link to comment Share on other sites More sharing options...
[Re...] Posted April 25, 2022 Share Posted April 25, 2022 Hello, the workaround could be to copy the "plugin_post_feature_pcm.txt" after loading the actual measurement plan. Make a "inspection_post_load_pcm.txt" file to copy the files while loading the plan. for Example: if fileExists("plugin_postFeature_pcm.txt") == false mysource = "C:\Users\Public\Documents\Zeiss\CALYPSO 7.2\workarea\inspections\plugin_postFeature_pcm.txt" myfile = getActualInspectionDir()+"\plugin_postFeature_pcm.txt" copyFile(mysource,myfile) endif both files has to be in the global inspection folder...... Good luck Link to comment Share on other sites More sharing options...
[Je...] Posted April 25, 2022 Author Share Posted April 25, 2022 Thanks, I had not thought of that. Seems like a decent workaround. Will try this out. Link to comment Share on other sites More sharing options...
[Ka...] Posted August 4, 2022 Share Posted August 4, 2022 Hello I have a question about plugin files. I tried to use it and mostly works, but not all information can be extracted from features/characteristics. I need to extract the name of the characteristic which running now. if I use in the characteristic pre/post settings (inside measurement plan) name = getNominal().identifier then give me information which I need but the same command in the file plugin_preCharacteristic_pcm.txt or plugin_postCharacteristic_pcm.txt give me an error message. please help (Calypso 5.8) Link to comment Share on other sites More sharing options...
[Is...] Posted August 4, 2022 Share Posted August 4, 2022 Please sign in to view this quote. it works OK in Calypso 2020... Link to comment Share on other sites More sharing options...
[Ka...] Posted August 4, 2022 Share Posted August 4, 2022 in 6.8 (2019) don't I don't have 7+, what can I do in 5.8? Link to comment Share on other sites More sharing options...
[Is...] Posted August 4, 2022 Share Posted August 4, 2022 Please sign in to view this quote. to buy a software upgrade.. 😐 Link to comment Share on other sites More sharing options...
[Is...] Posted August 4, 2022 Share Posted August 4, 2022 Please sign in to view this quote. The last 5.8 version is: 5.8.2810, check if it works there... Link to comment Share on other sites More sharing options...
[Ka...] Posted August 4, 2022 Share Posted August 4, 2022 No it doesn't work. Was tested on 3 different installation. 2x 5.8.2810 and 6.8.20 Link to comment Share on other sites More sharing options...
[Is...] Posted August 4, 2022 Share Posted August 4, 2022 Please sign in to view this quote. If you see: in the error message that you have is not indicated on the characteristic; it comes from somewhere else, you should have an indication of where is located the error (see my screeenshots). Then maybe you have the command somewhere else, if not, definitely is a software bug…2022-08-04_16h06_52.png2022-08-04_15h59_57.png Link to comment Share on other sites More sharing options...
[Ka...] Posted August 4, 2022 Share Posted August 4, 2022 Is no other formulas. This is a program which was created to show issues. Simple program with characteristics (all PCM windows is empty) and plugin file in the program folder. Nothing else. I need to grab the name of the characteristic without program edit. Around 1000 programs with a long list of characteristics. Maybe someone knows the different solutions to extract the name of characteristics, but not all, this one only which is used in the current measurement (without masked, out of miniplans, or excluded thru condition) Thanks for help Link to comment Share on other sites More sharing options...
[Is...] Posted August 4, 2022 Share Posted August 4, 2022 Please sign in to view this quote. maybe your SW version is not newer enough to report the BUG, but you could try.. Link to comment Share on other sites More sharing options...
[Ka...] Posted August 4, 2022 Share Posted August 4, 2022 Even if Zeiss makes a new SP, I can't install it because the system is under control after validation, now nobody giving permission to install anything new. I have to use what I have. Do you know any other solution? Link to comment Share on other sites More sharing options...
