Bug: PCM Formula issue when using Symmetry Points
I noticed this today.
Image named: PCM Formula Bug 08.22.2022 RS 1.JPG
1st image to show steps to the error
Open feature
...Open Strategy
......Open Point List
Selected Z Coord 0.072500 to add a formula (simple math)
Image named: PCM Formula Bug 08.22.2022 RS 2.JPG
Shows Formula dialog box open and the PCM string (This is opened by right clicking the mouse and selecting "Formula".
Image named: PCM Formula Bug 08.22.2022 RS 3.JPG
Shows the same Z Coord selection now highlighted in Yellow due to entering a formula value.
Take note of the X Coord box where the 0.000000 value was, has changed to 0.147500 while the chosen selection remains the same value while highlighted.
Take note the value in X Coord is not the correct calculated value from the PCM formula entered.
PCM Formula Bug 08.22.2022 RS 1.JPGPCM Formula Bug 08.22.2022 RS 2.JPGPCM Formula Bug 08.22.2022 RS 3.JPG
Probably not a bug but a feature. Per default the formula inserted will be in reference to the coordinate system selected in the feature. So when you input 0.0725 in the formula you are not inputting the z-value in the feature alignment (which is half the symmetry point width) but in the alignment selected in the feature (Base Alignment in this case).
This can be changed with the button PCM-ref that you can see in your last image.
