[Je...] Posted July 29, 2022 Share Posted July 29, 2022 . Easy question: Is there a way to send multiple pdfs of different templates to the same directory but specify different naming? For example, I want to send both a Standard Protocol and Plot Protocol template to the same directory. I want them both to have the exact same file name except for the plots report should end with the word "plots." How do I do this? Currently, it sends both pdfs to the same folder and gives the first report in the multiple reports list a suffix of (1) and the 2nd report gets a suffix of (2). Example: Part01(1).pdf, Part02(2).pdf . . . Link to comment Share on other sites More sharing options...
[Ch...] Posted July 30, 2022 Share Posted July 30, 2022 That way I do this is with batch/vbs files. When the program ends, I run a batch file that looks for the "(1)" and the "(2)", then it sends them do different folders based on that. Link to comment Share on other sites More sharing options...
[Je...] Posted August 1, 2022 Author Share Posted August 1, 2022 Please sign in to view this quote. . Thanks, Chad. By any chance, could you send me a copy of your batch file, so I can use it as a template? . Link to comment Share on other sites More sharing options...
[Ch...] Posted August 2, 2022 Share Posted August 2, 2022 robocopy "Q:\CMM Results" "Q:\CMM_Receiving_and_FAI_Reports" *(1).pdf /move /s /MT32 /Z /tee Here is the line of code from my robocopy script that is triggered by the REPORT_END.BAT. So here, the (1)s are moved to a different folder, and the (2)s stay. but you could send them where ever. Link to comment Share on other sites More sharing options...
[Ri...] Posted August 2, 2022 Share Posted August 2, 2022 Here are some example file naming PCM routines I use. Editing these will help you name files how you want. Characteristic Table Files "C:\Users\Public\Documents\Calypso Results Data\Text files"+"\"+getRecordHead("order")+"\"+getRecordHead("planid")+"_SN_"+getRecordHead("partsn")+"_"+getRecordHead("partnbinc")+"_chr.txt" Feture Table Files "C:\Users\Public\Documents\Calypso Results Data\Text files"+"\"+getRecordHead("order")+"\"+getRecordHead("planid")+"_SN_"+getRecordHead("partsn")+"_"+getRecordHead("partnbinc")+"_fet.txt" Report header table files "C:\Users\Public\Documents\Calypso Results Data\Text files"+"\"+getRecordHead("order")+"\"+getRecordHead("planid")+"_SN_"+getRecordHead("partsn")+"_"+getRecordHead("partnbinc")+"_hdr.txt" The above creates folders in the following structure: This is where all Table files are saved. (You can change drive and or folder names) C:\Users\Public\Documents\Calypso Results Data\Text files\ Measuring points (.zmp files) "C:\Users\Public\Documents\Calypso Results Data\ZMP files"+"\"+getRecordHead("order")+"\"+getRecordHead("planid")+"_SN_"+getRecordHead("partsn")+"_"+getRecordHead("partnbinc")+".zmp" The above creates folders in the following structure: This is where all Table files are saved. (You can change drive and or folder names) C:\Users\Public\Documents\Calypso Results Data\ZMP files\ PDF file PiWeb reporting "C:\Users\Public\Documents\Calypso Results Data\PDF files"+"\"+getRecordHead("order")+"\"+getRecordHead("planid")+"_SN_"+getRecordHead("partsn")+"_"+getRecordHead("partnbinc")+".pdf" The above creates folders in the following structure: This is where all Table files are saved. (You can change drive and or folder names) C:\Users\Public\Documents\Calypso Results Data\PDF files\ Link to comment Share on other sites More sharing options...
[Je...] Posted August 2, 2022 Author Share Posted August 2, 2022 Please sign in to view this quote. Please sign in to view this quote. . Thank you kindly, sirs. . Link to comment Share on other sites More sharing options...
