Report Header Parameters
Other than a template program, is there a way to preserve a select group of report header parameters for new measurement plans?
2nd question: I know if I customize a standard protocol template and save it over the original template in the Default templates folder, that it will be used on any new program. (Similar to saving a custom presentation template in the Default folder on pre-PiWeb systems). Again, other than selecting it in a template program, is there a proper way to have the customized template become the default template?
C:\Users\Public\Documents\Zeiss\CALYPSO\data\protocol header
use the Save button and rename the file. They are stored in the file path above.
Ok. I saved it but it did not load automatically in new program. Is it still a manual open and load?
I have to manual load that file every time I write a new program; However, I haven't tested it on a template. I'll do some testing and see what I can come up with.
  • 3 years later...
Is there a way to apply this file to old programs, I have several hundred programs that need to be updated to our new header.
  • 3 weeks later...
Another option would be to use PCM Start files to define and set reports in a more global manor vs on an individual program to program basis. For example - CALYPSO: PCM - How to Make a Script work for many Plans.
If you pair this with "PCM functions: Report commands" in section 1-134 of the attached PCM Manual Calypso_02_pcm.pdf you can get a very similar end result to what you are looking for.
  • Like! 1
  • 3 months later...
I can make something, but i have a little time for that.
I still work on my app for Calypso programs, but i have a little free time.
Since i have not looked into this problem i would need whole program before and after to find differences ( can be dummy one ) and i'll prepare an app where you will select all programs which you want and source of headers. It will make changes for all selected programs.
For anyone interested here is checked settings in "inspection" file ( from one of my programs ):
phParaFor_E -> in Edit mode
phParaFor_R -> seems like for run / i have drawingno fixed in edit mode, so in RUN there is no field to fill this
#phParaFor_E ' ->'
#OrderedCollection
#drawingno
#u_kontrolor
#partid
#u_field4
#u_field5
#order
#u_field6
#aname
#u_znaceniDilu))
#phParaFor_R ' ->'
#OrderedCollection
#partnbinc
#order
#u_field6
#u_kontrolor
#palletlocation
#u_field7
#u_field4
#u_field5
#u_znaceniDilu)))
Also filled header with data is in same file:
#userDic:
#Dictionary
#aname ' ->' 'TEXT')
