[Th...] Posted August 1, 2022 Share Posted August 1, 2022 Why can't I use the cylinder for rotation on the base alignment? base alignment.PNGFetching info... Link to comment Share on other sites More sharing options...
[Ma...] Posted August 1, 2022 Share Posted August 1, 2022 A cylinder is essentially a 3d line. The rotation is not being stopped by the axis of the line. Try using a circle, that will give you a point where the rotation is stopped. Link to comment Share on other sites More sharing options...
[To...] Posted August 1, 2022 Share Posted August 1, 2022 you could also use an Intersection Construction of the Cylinder and the Plane, which creates a point, similar to Mark's answer. Link to comment Share on other sites More sharing options...
[Th...] Posted August 1, 2022 Author Share Posted August 1, 2022 So if I go with Intersection Construction and set that as the +Y alignment, when I remeasured the cylinder, the X axis will always be off to one side or the other but never at 0. What can I do to set the cylinder as 0 on X axis? Link to comment Share on other sites More sharing options...
[Dy...] Posted August 2, 2022 Share Posted August 2, 2022 Draw a 3d line from the circle to cylinder then project it up to the plane and use that as your rotation? Link to comment Share on other sites More sharing options...
[Ph...] Posted August 2, 2022 Share Posted August 2, 2022 Please sign in to view this quote. Recall the feature points of the cylinder into a circle and use it as the planer rotation. This can produce same behavior that takes place within a position characteristic when cylinders that have the same normal vector are used as secondary & tertiary datum references with "ISO 5459" constraints applied. Link to comment Share on other sites More sharing options...
[To...] Posted August 2, 2022 Share Posted August 2, 2022 Please sign in to view this quote. In the Base Alignment window, change the direction to +X Link to comment Share on other sites More sharing options...
[Er...] Posted August 2, 2022 Share Posted August 2, 2022 In the Base Alignment choosing +X as the planar axis should work. Link to comment Share on other sites More sharing options...
