Input Parameters Do Not Autofill
Issue with the Input Parameters not carrying over to the other palette locations for my data output. We fill in the input fields, click ‘OK’. Then we can normally click ‘Cancel’ and ‘Yes’ to carry our inputs through for the remaining palette locations.
Also, can anyone make sense of the error. Can run 200 parts and then stops intermittently. Happens in the middle of running a pallet while machine is probing a part (probe stays in contact when machine stops) Any thoughts
Program has been running fine on 1 machine. These errors are occurring on new 2nd machine.
Palette is not able to save and load automatically - you have to set up in parameters of palette for every nest.
Only autoincrement on part n. is able to transfer with asterisk "*".
Customer says it works on 1st machine. I just tested on my Planner seat (7.2.12 2021 SP3) and it works like he said.
You're right that the values are not saved but just load the values on the 1st part, click Cont. Then, click Cancel on 2nd part. Click Yes on dialog box below and values will transfer to the rest of the parts automatically.
Cool. I didn't know this. When did they add this feature? I must have missed something in the release notes.
I made a PCM script many years ago to do exactly this.
