Piweb Monitor Not Opening Correctly
Hello Everyone!
I am having a slight issue with my Piweb this morning. I had it working about an hour ago but somehow it no longer works. When I run any of my reports (using F11), it acts like a new window is opening, but the new window is glitched and can't be opened. The window shows it as being open in the hotbar (see attached image). I tried changing settings to open it in full screen, which works a little bit, opening the full screen view, but if minimized it is lost again.
Problem solved. Had to right click the preview of monitor and click maximize. It was opening off screen before this setting was changed.
