[Mi...] Posted July 29, 2022 Share Posted July 29, 2022 I have a cylinder with 5 holes drilled in the sides at equal distance around the cylinder. how do I change my holes on the cad model to measuring pins inserted in the holes instead? thanks Link to comment https://qualityforum.zeiss.com/topic/9884-cad-model-help/ Share on other sites More sharing options...
[To...] Posted July 29, 2022 Share Posted July 29, 2022 one method is to extract each cylinder. Next, open each cylinder and toggle the ID/OD switch next to label. Then, edit the start height and target height out to beyond the outer surface of the part. Edit the start angle and angle range, too. Keep angle range under 180° to prevent movement under pin. Or, use 2 separate circle paths to go back and forth. I suppose you could do the exact same thing with circles. I believe you could also do a rotational pattern to keep strategy editing simple. Link to comment https://qualityforum.zeiss.com/topic/9884-cad-model-help/#findComment-46910 Share on other sites More sharing options...
[Mi...] Posted July 29, 2022 Author Share Posted July 29, 2022 Thanks Tom Link to comment https://qualityforum.zeiss.com/topic/9884-cad-model-help/#findComment-46912 Share on other sites More sharing options...
