Calypso TP
Whats the difference in Align Of Feature and Base Alignment in the true position box??
When I go in and ask for a TP calypso seems to default to Align To Feature.
Never really paid much attention to it until today. I do not use a lot of TP around here...
I've not noticed that. In case you haven't seen this feature, You can select your Datums, and then "save as" a named set. After that, it will be in the drop down menu.
Unless you properly build the alignment using the can/may/must rule, then you will possibly see differences between alignment of feature and if you manually built the DRF.
Also typically the Base Alignment doesn't follow OTE and/or ISO5459.
Richard, is there a provision for custom DRF ? I think ASME Y 14.5-2009 onwards allows it, but I don't see how to implement that without using alignment to do so.
No - you would have to use an alignment to achieve that.
I am not opposed to people using alignments for their Positions/Profiles - I do it a lot myself.
I just see a lot of people, fresh or not using the Base Alignment as their DRF and their Base Alignment is not built correctly to match their DRF as noted on the drawing.
