[Da...] Posted July 26, 2022 Share Posted July 26, 2022 The other day I programmed a relatively complex mold insert that looked like a three lobed ,evenly spaced group of features. So, i merrily programmed a bunch of space point on one of the lobes, grouped and then patterned the group. The part ran pretty good but they were having trouble dialing in the electrodes. I went out to see, and they showed me a PRINT ! Right there I saw it ! Two of the lobes were at 120 degrees separate but one was at 121.5 degrees ! WHO DOES THAT ???? I started over and reprogrammed the whole part, ( using all single space points) but what a pain in the arse ! The part ran pretty good, but had to do a lot of apologizing ! Remember ! The model is stupid, and so are you . It will do whatever you ask it to even if it's wrong. Link to comment Share on other sites More sharing options...
[Je...] Posted July 26, 2022 Share Posted July 26, 2022 Please sign in to view this quote. . Sometimes the reason symmetry is intentionally broken is to add distinction or prevent installation error. It can be a very useful design habit. . Link to comment Share on other sites More sharing options...
[Da...] Posted July 26, 2022 Author Share Posted July 26, 2022 It was necessary, But I would have liked to see a warning of some sorts... But then again, I didn't see the print till after I programmed 😉 Link to comment Share on other sites More sharing options...
