Can I send graphics elements to a file other than results ?
Yes, through multiple printouts. Filenames and directories can be specified. But if the network is down...
Another way is to do an inspection end batch file that copies to the network. I'll see if I can find that post.
If you are using Multiple Reports, then it's done in the multiple reports window. Otherwise, it is handled in Resources > Name for Output files.
Thanks for the links, I haven't had a basics class in over16 years. And we didn't get a piweb manual or training...
  • 1 month later...
We just had the server go down and lock up Calypso. 🙁
I added this to my inspection_end.bat file and set multiple printouts back to the results folder. The odd start to the filename is so I can copy only the gra.pdf file.
REM copies only newer 23665_B_ PDF files to server
XCOPY C:\Users\Public\Zeiss\Calypso\home\om\workarea\results\23665_B_*.pdf "S:\502-Public\Zeiss Results\_Run Reports" /d
