Value not permitted for RT
A similar message appears at the start of program for RT-AB if you start the program and the potentiometer knob is not at the max (full speed).
Of course it doesn't tell you much just: illegal pot value for RT then bombs out....
It should say: please turn knob to max to start, and then allow you to continue ...
with RT-ABs, you must establish the MMI at least once per part. If you haven't defined the MMI for that program yet, then I think you get this error.
