dmo with calypso???
Hello
i need to get the "dmo" file with calypso is it possible?? the "dmo" file contains the dmis information correct?
i have the "output in DMIS format" license but it export in "dp" files. My client says that this is not what he wants it has to be in "dmo".
in the case of dp files the name of the characteristics is not as it is in the measurement program, it only has 10 characters.
it is possible to change it to the 14 characters that we have in the program?
thanks
Per a Google search and the PC-DMIS forum, dmo files are the output files.
In the Name For Output Files you can change the filename extension to .dmo instead if you'd like.
"+getRecordHead("planid")+".dmo"
All of these dmis files are just txt files at the end of the day.
I was digging around in settings, and found what you were looking for on the length of the feature/characteristic.
Resources - Combability Settings - for this Measurement Plan/for Multiple Measurement Plans.
