[Th...] Posted July 13, 2022 Share Posted July 13, 2022 Could you use a disk probe to scan a plane/line or is it strictly for ID/OD only? Link to comment Share on other sites More sharing options...
[Ri...] Posted July 13, 2022 Share Posted July 13, 2022 I don't even like doing disc probes. So many limitations and a pain to setup correctly. I used to say that were no, but I've been corrected, so now I say there are few cases were you absolutely have to use a disc. Most of the time you can build a star or t-shaped stylus systems. Link to comment Share on other sites More sharing options...
[Za...] Posted July 15, 2022 Share Posted July 15, 2022 Please sign in to view this quote. We have many parts that have undercut diameters that are underneath the threads and there isn't a ton of room to get a ball stylus in there so we use disk styli. I'll say this, since you have to constantly offset your X/Y/Z values manually for a disk stylus, locations tend to not come in as accurate for me, but the disk styli always seem dead nuts on diameters. Link to comment Share on other sites More sharing options...
[Da...] Posted July 17, 2022 Share Posted July 17, 2022 if its +/- 0.1 mm and shape is no problem, why not if its something accurate then not. i think this is awesome: (search for L-stylus if the link dies) https://shop.metrology.zeiss.com/INTERS ... tion=false just need some adapter Link to comment Share on other sites More sharing options...
