Setup Sheets
I'm in the process of creating a setup sheet depicting stylus system and fixturing setups and was wondering if anyone had a sample setup sheet they'd be willing to share on the forum?
TIA
I was only doing fixturing setups in 3D PDF ( I did all models of kit, then assembly and save as 3D PDF )
We do not need stylus infos ( using mainly only 6 configs )
I just use power point. I take pictures of everything and add a description of what a person needs to know(probes required, fixtures, fixture location, and how the part needs to be aligned on the fixture. I use a batch file "inspection_post_load" to make the power point open automatically when the program is opened.
