[Da...] Posted June 24, 2022 Share Posted June 24, 2022 I haven't used an rds in over 10 years. So I programmed some Z minus points with the probe at 90,90. I programmed an rds rotation point far above the part, so as not to impact the table or part. The machine goes to Y plus clearance plane and starts to rotate right there without moving to the Z+ location. I E-stopped the rotation before hitting the plate. What am I doing wrong??? Link to comment Share on other sites More sharing options...
[To...] Posted June 24, 2022 Share Posted June 24, 2022 Please sign in to view this quote. Is your +Z clearance plan above the part? Are you trying to do an index within a strategy using position points? Link to comment Share on other sites More sharing options...
[To...] Posted June 24, 2022 Share Posted June 24, 2022 In my example, I am taking a point on the shoulder with a long probe tilted at A0 B-87.5 then to avoid going up to index to A0 B-90, at standard safe position to measure the c'sink and smaller ID, I use several position points. The problem is a position point that involves an index is that it will do the index first and then move to the position. So, generally an extra position point might be required. See attachedposition points.pdf Link to comment Share on other sites More sharing options...
[Da...] Posted June 24, 2022 Author Share Posted June 24, 2022 I do a 2d line under the part, then I am doing a small space point group, that's also under the part, then I want to retract and go to the rotation point I created using rotation/swivel position. R/S probe to 0,0 and proceed with the rest of the part. What is the rotation/swivel position used for? Link to comment Share on other sites More sharing options...
[To...] Posted June 24, 2022 Share Posted June 24, 2022 Please sign in to view this quote. Swivel position controls where all RDS indexes take place, instead of automatically clearing the +Z CP only. If the next feature uses A0B0, you don't need a swivel position. If your line and space points are all using the same stylus angle and are all using CP+Y, it should go out and up and index above the +Z CP for the next feature. Tip. If the path between the line and the space points, and the path between all of the space points have no interference or obstructions between them, i.e. line of site, try using SCP+Y for the line and all of the space points. That will keep the stylus from coming out to the +Y CP between the line and all of the space points. Link to comment Share on other sites More sharing options...
[Da...] Posted June 24, 2022 Author Share Posted June 24, 2022 So , my machine is doing the points ,going to Y+ clearance plane and trying to rotate there. If it would go to Z+ clearance plane first it would be fine. Do I need to block edges? Link to comment Share on other sites More sharing options...
[To...] Posted June 24, 2022 Share Posted June 24, 2022 Please sign in to view this quote. No. By default, RDS rotations between features (not within a strategy window) will go up to a point above the CP+Z as if the probe was at A0B0. Link to comment Share on other sites More sharing options...
[Da...] Posted June 24, 2022 Author Share Posted June 24, 2022 Well , it's not doing that right then... Could it be that the next feature is another space point ? I guess I can put in cmm position points on the last space point, but we change and group points frequently...what happens if that point is moved ? Link to comment Share on other sites More sharing options...
[To...] Posted June 24, 2022 Share Posted June 24, 2022 Please sign in to view this quote. I just sent you a PM Link to comment Share on other sites More sharing options...
[Er...] Posted June 27, 2022 Share Posted June 27, 2022 I had something similar happen to me. Turned out I had edited the strategy with a different angle selected. Open the Strategy-Probing point-Stylus This will list the stylus tips used in the strategy. Normally these would all be the same. Link to comment Share on other sites More sharing options...
