[Da...] Posted June 13, 2022 Share Posted June 13, 2022 Haven't used curve for over 8 years. I'm a bit rusty but, this is driving me crazy. I was trying to not utilize points from the beginning and end of a curve by asking to start at point 5 and end at point 495. but, it seems to be trimming only from the end. Should I be using some other way to remove those points from the curve ? ❓ Link to comment https://qualityforum.zeiss.com/topic/10222-having-some-trouble-with-curve/ Share on other sites More sharing options...
[Ma...] Posted June 14, 2022 Share Posted June 14, 2022 Are you asking: how to remove nominal points from curve how to keep nominals, but to have scanning path shorter exclude measured points from evaluation I don't use auto-red marking points like on basic features - i had to manually turn this on on features edit window even when i filled numbers beginning/end. I rather use manual selection ( reducing by length - min. 1/2 of scan speed ) Link to comment https://qualityforum.zeiss.com/topic/10222-having-some-trouble-with-curve/#findComment-48818 Share on other sites More sharing options...
[Da...] Posted June 15, 2022 Author Share Posted June 15, 2022 All of the situations that you mentioned... Link to comment https://qualityforum.zeiss.com/topic/10222-having-some-trouble-with-curve/#findComment-48820 Share on other sites More sharing options...
[Ma...] Posted June 15, 2022 Share Posted June 15, 2022 Oh that's for big answer 🤣 Removing nominals from curve Open curve feature Open list of nominals ( little arrow on left side ) Select points to remove - mouse right click and remove Reduce scanning path Open curve feature Open strategy Open Segment Edit point numbers "From" and "To" Exclude measured points Open curve feature Open evaluation Check this checkbox and click settings ( sorry for no-english picture ) Select points which will be excluded from evaluation ( missing in PiWeb, not used for callouts and bestfitting ) Link to comment https://qualityforum.zeiss.com/topic/10222-having-some-trouble-with-curve/#findComment-48822 Share on other sites More sharing options...
[Da...] Posted June 16, 2022 Author Share Posted June 16, 2022 Thank you Martin ! Link to comment https://qualityforum.zeiss.com/topic/10222-having-some-trouble-with-curve/#findComment-48824 Share on other sites More sharing options...
