Table OK/NOK sign for dimensions in trend project
Dear GOM Team,
I would like to make an extra column in the "Statistic RPS" table format which shows if a dimension (row) fails on any of the stages. So for ex. if a dimension fails on any stages it shows 'nOK' other way it shows 'OK'.
Besides I would like to make a "functional label" on the first page (title) which shows if any of the dimensions from the elements fails. Also OK/NOK sign or any kind of sign would be good.
Do you have any nice solution for these?
Best regards,
Máté Tömöri
  • 3 weeks later...
Hello Máté,
for the OK/nOK column you could insert this expression:
#@ OK nOK Check
niO = "nOK"
iO = "OK"
if result_worst_case < result_dimension.lower_tolerance_limit or result_worst_case > result_worst_case.upper_tolerance_limit:
	a =format (niO, "", show_unit=false, color=color ("#ff0000ff"))
else:
	a = format (iO, "", show_unit=false, color=color ("#13d373ff"))
return a
It checks if the worst case is out of your tolerances. For the tolerance status you could use the Keywords project_statistics.all.number_of_within_tolerance and project_statistics.all.number_of_toleranced_attributes in a label on the title page. They are also available for individual element types. The label needs the information from a 3D view, so there has to be a placeholder for this on the title page with all checks visible somewhere. The size doesn't matter though, it could be tiny or behind some element.
#@ Not yet named
#@ OK nOK Check
niO = "nOK"
iO = "OK"
if project_statistics.all.number_of_within_tolerance < project_statistics.all.number_of_toleranced_attributes:
else:
return a
Regards,
Nanno
Hello Nanno,
Thanks, we are getting closer but not work properly yet.
The table and the title page also just shows the actual stage. Worst_case depend on the actual stage too unfortunately.
My idea is to insert somehow Min/Max (from Statistic Overview) to your expression but some problems occured what I could not handle.
Best regards,
Máté
2.thumb.PNG.f8224f7b180787b87dbf1d168c5a668a.PNGp1.thumb.PNG.c57601126996f3ba7ab4f0bed720f105.PNGp2.thumb.PNG.5954b91a8b9b9cdb2548d2ba731946ae.PNG
Hello,
For a similar functionality I count the number of result_dimension.out_of_tolerance. The number of stages (parts) that are out of tolerance
count (result_dimension.out_of_tolerance>0, index='stages')==INVALID?
	"0":
    format ((count (result_dimension.out_of_tolerance<0, index='stages')
             +count (result_dimension.out_of_tolerance>0, index='stages')), "1.0", show_unit=false)
(of topic:
I didn't know the python if then else syntax could be used in a expression)
Hello,
I solved the first problem include min/max into the function.
I still could not solve the second question which is how to show on one label that all the dimensions are good or not.
for general dimensions:
#@ OK nOK Check
niO = "nOK"
iO = "OK"
if result_dimension.is_tolerance_used:
    if (max (result_dimension.deviation)) > result_dimension.upper_tolerance_limit or (min (result_dimension.deviation)) < result_dimension.lower_tolerance_limit:
    else:
else:
    a = ''
return a
for Gdnt:
#@ OK nOK Check
niO = "nOK"
iO = "OK"
if result_gdat_size.is_tolerance_used:
    if (max (result_gdat_size.deviation)) > result_gdat_size.upper_tolerance_limit:
    else:
else:
    a = ''
return a
Ok_nOk sablon.packageFetching info...
