[An...] Posted May 19, 2022 Share Posted May 19, 2022 Alright people I use Duramax(Measuring rang 18" x 18" x 18") and got the requirements from customer. I have no idea, is there person who can explain that requirement easily. Please see attached. -I am looking for the artifact, can you share the link for me PLEASE PLEASE0519.JPG Link to comment Share on other sites More sharing options...
[Ju...] Posted May 19, 2022 Share Posted May 19, 2022 An artifact is an object with known dimensions to compare to the CMM measurements. I don't think they are referring to a specific artifact. Link to comment Share on other sites More sharing options...
[Ow...] Posted May 19, 2022 Share Posted May 19, 2022 If you're looking for squareness, a lot of CNC machine maintenance people have these that they use to square machining centers in with when moved Maybe you could borrow or purchase one if you don't have one.. https://store.gaging.com/12x12x3a6ms-pr ... 12-h-x-3-w I used to use one of these at another facility and it offers a little more verification methods than just squareness but, nothing like the artifacts Zeiss sales. https://willrich.com/product/glastonbur ... ick-check/ https://www.zeiss.com/metrology/product ... facts.html Link to comment Share on other sites More sharing options...
[Er...] Posted May 20, 2022 Share Posted May 20, 2022 The document specifically says a ball bar or long gage block is typically used. I could not find info in the Zeiss Portal's "Knowledge Base." precisionballs website has good information. Google "ball bar" cmm squareness Link to comment Share on other sites More sharing options...
[An...] Posted May 20, 2022 Author Share Posted May 20, 2022 Please sign in to view this quote. Thanks Owen, but it says 40 % of the available traveling.... (Measuring range for Duramax)18" x 18" 18" ->40% -> 7.2" x 7.2" x 7.2" Link to comment Share on other sites More sharing options...
[To...] Posted May 23, 2022 Share Posted May 23, 2022 DuraMax is 500mm x500mm x 500mm (20" x 20" x 20") Link to comment Share on other sites More sharing options...
[Ri...] Posted May 23, 2022 Share Posted May 23, 2022 Could you just not show the Spatial checks from the calibration protocol? Zeiss does all this for you when they calibrate the machine, and as long as you are calibrating yearly, I don't see why you would need to come back behind them an perform a check that isn't even as robust or accurate as what they are doing. Link to comment Share on other sites More sharing options...
[An...] Posted May 23, 2022 Author Share Posted May 23, 2022 Please sign in to view this quote. The customer wants...... every month.... Link to comment Share on other sites More sharing options...
[Da...] Posted May 23, 2022 Share Posted May 23, 2022 You could purchase a complete solution with an artifact and ready to go measuring plans from Zeiss. Sure, it's expensive, but... well, you know... Zeiss. Link to comment Share on other sites More sharing options...
[An...] Posted May 24, 2022 Author Share Posted May 24, 2022 Please sign in to view this quote. Expensive? we are ok our customer is going to purchase haha Link to comment Share on other sites More sharing options...
