Tangential Probing
Like said before, you can deactivate the "Navigator" license, if never needed.
Or you can define a preset for each feature strategy.
Save /load defaults. If you have an angle set for the scan as the default then it won't choose tangential. Been working for me... 128_cf16b6f545a71c167763d4a7b8328d2d.jpg
I have to ask "what is tangential probing"? I have never turned it on before. I found the "basics about tangential probing" in the user guide but I am still not sure.
Normally tip goes to touch, then runs a circular scanning.
Tangential starting close to material and running circular path slowly increasing in diameter to gentle touch material.
Machininst can show you same thing with cutting tools.
