E4 on the air filter system question
How often do you guys change these out ? We've had the machine for a year and half and this now just occurred. If the liquid coming out is brown what does that mean? Bad air quality ?
The brown fluid should be oil from the air compressor. That is not unusual. In fact it has been an issue at several jobs.
Oil in the air can shorten the life and destroy the air bearings. Water will do similar things.
viewtopic.php?t=10006
I struggled with this problem years ago. Although the compressor feeding the system was also a dryer, I had to change the filters frequently because water and oil came.
We finally solved the problem by getting the following refrigeration dryer. It runs both of our 2 contura devices.
I don't use the filters that come with Zeiss
It changes the filters according to the service maintenance period. I don't need to follow 2500_fe73c1e9781db7db19ae13dd09fe715e.png
