Excel name + location
We are running a large number of in-process inspections, the parts are serialized in 10's - 10-20-30 etc. My query is 2-part: is there a way to make the excel report number the output file automatically according to the serial number, and is there somewhere we can have it saved to a specific directory other than the default "results"?
  • 3 years later...
Thank you very much for this!
I added time stamp and a little bit of sleep! (Otherwise Calypso 5.4 wasn't happy in my case.)
set CUR_YYYY=%date:~10,4%
set CUR_MM=%date:~4,2%
set CUR_DD=%date:~7,2%
set CUR_HH=%time:~0,2%
if %CUR_HH% lss 10 (set CUR_HH=0%time:~1,1%)
set CUR_NN=%time:~3,2%
set CUR_SS=%time:~6,2%
set CUR_MS=%time:~9,2%
set SUBFILENAME=%CUR_YYYY%%CUR_MM%%CUR_DD%_%CUR_HH%%CUR_NN%%CUR_SS%
timeout /t 5 /nobreak > NUL
taskkill /im excel.exe
set _source="C:\Program Files (x86)\Zeiss\Calypso\home\om\workarea\results"
set _target="\\network_storage\test_folder"
FOR /F "delims=" %%I IN ('DIR %_source%\*.xls /A:-D /O:-D/T:C /B') DO MOVE %_source%\"%%I" %_target%\"%%I"_%SUBFILENAME%.xls & GOTO :EOF
Time stamp source -> https://tecadmin.net/create-filename-wi ... ch-script/
My apologies. I was only trying to offer info on saving files to a unique location.
Unfortunately, I don't believe saving the actual "Excel" format report anywhere but the Results folder is an option. In the past, the Zeiss Hotline would tell you to save the Characteristics table file as an .xls using Name for Output File as the solution.
I wish I had more to offer.
