[Er...] Posted January 11, 2022 Share Posted January 11, 2022 I can't figure this out. Usually when I select a surface to create the feature it will display on the model as a bright magenta color. Now when I select a model it doesn't show at all. Under CAD/Settings/Colors selection shows the color it should be. Any ideas? Link to comment Share on other sites More sharing options...
[Ju...] Posted January 12, 2022 Share Posted January 12, 2022 I think what you're looking for is in the Model Display section of the settings.ForumHelp.jpg Link to comment Share on other sites More sharing options...
[Er...] Posted January 12, 2022 Author Share Posted January 12, 2022 Great suggestion. This is checked, so unfortunately, something else is going on. Link to comment Share on other sites More sharing options...
[Ma...] Posted January 12, 2022 Share Posted January 12, 2022 I've had missing surfaces on the model and tried CAD/ CAD File/Automatic Healing and they reappeared. Don't know if it will work in your case but might be worth a try. Link to comment Share on other sites More sharing options...
[Ju...] Posted January 12, 2022 Share Posted January 12, 2022 Does displaying the strategy for the feature fix it?Strategy.jpg Link to comment Share on other sites More sharing options...
[Ma...] Posted January 12, 2022 Share Posted January 12, 2022 Maybe this one? Link to comment Share on other sites More sharing options...
[Er...] Posted January 12, 2022 Author Share Posted January 12, 2022 Again, Great suggestions. All of these are selected or checked. I tried Healing the model too. No such luck. Link to comment Share on other sites More sharing options...
[33...] Posted January 12, 2022 Share Posted January 12, 2022 Silly suggestion, but is it just happening on one model? The reason I ask is because I was working on a project where the model actually had 2 surfaces overlaying each other. 2 surfaces, on every single surface, in the exact same location. I could delete one surface from Modify CAD entities and then I'd see the highlighted surface. Link to comment Share on other sites More sharing options...
[Er...] Posted January 12, 2022 Author Share Posted January 12, 2022 If I recall this is the 2nd or 3rd model I have seen it on. I checked the CAD Hierarchy and this is the only model showing. Link to comment Share on other sites More sharing options...
[Da...] Posted January 31, 2022 Share Posted January 31, 2022 i have the same problem, i cannot edit becouse i do not see what im doing and here its something with old programs when i import the same CAD to new programs i see everything i think previous users make some "favour" for us, i do not know how to fix it now, i also tried everything. Link to comment Share on other sites More sharing options...
[Da...] Posted January 31, 2022 Share Posted January 31, 2022 Have you upgraded to a newer version of Calypso? I had this same issue. I could see it with the wire frame model. Have you tried to delete and reload the model? Link to comment Share on other sites More sharing options...
[Da...] Posted January 31, 2022 Share Posted January 31, 2022 Thank you i did it like its here -Go into Cad>Modify Cad Entities>Hierarchy -Select your old model and delete it -Simply load your new model and orient it to the correct position -Save the model and in wireframe i cannot see it cannot upgrade program becouse they are making it not compatibile with little bit older machines and its risk of neccesary upgrading some electronic inside and company will not take this risk and not pay, its too much. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 1, 2022 Share Posted February 1, 2022 Last try can be: go to CAD -> Modify CAD entities -> Edit page and click on button "All Features visible" That's the last chance Link to comment Share on other sites More sharing options...
[Ri...] Posted February 2, 2022 Share Posted February 2, 2022 Try a "CAD model comparison". Its worked for me in the past. CAD ...Cad file ......CAD model comparison Link to comment Share on other sites More sharing options...
[Ni...] Posted April 13, 2022 Share Posted April 13, 2022 I just started having this exact same issue with all new programs i am making. Tried all solutions and nothing. Have you fixed it? Link to comment Share on other sites More sharing options...
[Lo...] Posted April 14, 2022 Share Posted April 14, 2022 Go to Cad, view, Redraw Cad model. This has always worked for me. Link to comment Share on other sites More sharing options...
[Da...] Posted April 14, 2022 Share Posted April 14, 2022 I've had a model turn black...no border lines , nothing but a black blob in the middle of the screen. We did nothing to bring this about. later the same day, I returned to the same program and the model was back to normal. We still have leftover lines showing on programs with no models. Even toggling between " show all cad features" and "show selected cad features" doesn't work all the time anymore. It seems to be getting worse over time. I am so frustrated with this program ! Link to comment Share on other sites More sharing options...
[Er...] Posted April 14, 2022 Author Share Posted April 14, 2022 This is definitely Gremlins that were not removed with the 2021 verision of Calypso. Hopefully with updates this will be corrected. Link to comment Share on other sites More sharing options...
