Installation of V7.7 on GomLinux 11
Hi,
Im trying to install V7.7 on New installed GOM Linux 11. However Im not able to open gom-installer.bin file after cliking on it.
Also tried with command prompt ,  done chmod and then typed file name.
Error displayed : ./gom-installer.bin : symbol lookup error: /usr/lib/libGLcore.so.1: undefined symbol: _glap1_Dispatch
Linux Version  gom-linux-11-8-64Bit
GOM Software verison  gom-v7.7-10-x86_64
Can someone help me and suggest whats going wrong.
Thanks in advance.
Regards,
Sham Wasu
Hello,
this was a somewhat known problem on GOM-Linux 11-8, glory days back then...
Open a text terminal and type the following:
cd /usr/lib
sudo rm libGLcore.so.1
sudo ln -s /usr/lib/libnvidia-glcore.so.XXX.XX libGLcore.so.1
This should do the trick. Please note that the version number of the "libnvidia-glcore.so" (XXX.XX) can vary. So just type /usr/lib/libnvidia-glcore.so. and press the Tab key afterwards in order to automatically insert the correct version number.
