[Ro...] Posted March 8, 2022 Share Posted March 8, 2022 What I need to make 3 sections of a part, one on centerline and one 20º on either side. I'm no mathematician, and I have no idea how to calculate.dgfkjuhdgfdgfdgfdgfkj.PNG Link to comment Share on other sites More sharing options...
[To...] Posted March 8, 2022 Share Posted March 8, 2022 Please sign in to view this quote. For center section, enter X and Y center 0.000. Enter 1.000 in X vector and 0.000 in Y and Z. Make sure expansion is large enough to reach part. Section. For 20°, enter the COS and SIN of 20° in the X and Y fields. Could be negative value for other side. 0.000 in the Z field. Make sure X and Y center values are 0.000 Or, create 2 alignments, rotating about Z at 20° and -20° Then, in the section window, enter X and Y center 0.000 and enter 1.000 in X vector and 0.000 in Y and Z. Make sure expansion is large enough to reach part. Section 1 at Base Alignment. Section 2 at Alignment1 and Section 3 at Alignment2section 20a.JPGsection 20b.JPG Link to comment Share on other sites More sharing options...
[Jo...] Posted March 8, 2022 Share Posted March 8, 2022 Please sign in to view this quote. I cheat and make calypso do the work. I oftentimes create theoretical features in odd alignments and use formulas to derive nominals for real objects. Make a rotated alignment and switch the plane and it will update the new nominals in that orientation. This is helpful in compound angles for cylinders etc.. Link to comment Share on other sites More sharing options...
[Ro...] Posted March 8, 2022 Author Share Posted March 8, 2022 Thank you both for your responses, but in the end i took the path of least resistance and just copied Tom's numbers. So in the end i learned nothing and i'm no smarter, but i got another program in the bag. Link to comment Share on other sites More sharing options...
[Cl...] Posted March 8, 2022 Share Posted March 8, 2022 I have used for many years the Electronics Vest Pocket Reference Book (copy write 1969). It has among other things, a table of sine's, cosines, and tangents. Very handy. Link to comment Share on other sites More sharing options...
[Ma...] Posted March 9, 2022 Share Posted March 9, 2022 If you would need it in future, then just use SIN and COS with angle - thats for 2d - for three axis is better to get help from elements 😃 Link to comment Share on other sites More sharing options...
[No...] Posted March 9, 2022 Share Posted March 9, 2022 Please sign in to view this quote. 🤣 🤣 🤣 A laminated version of this is my constant companion for more than 30 years now: https://docplayer.org/docs-images/55/35 ... s/17-0.png Link to comment Share on other sites More sharing options...
[Er...] Posted March 9, 2022 Share Posted March 9, 2022 Put in a magnitude of 1 and the angle. It helped me to see the relation between angles and vectors. Of course I had to do it on graph paper 😃 https://www.mathsisfun.com/algebra/vect ... lator.html Link to comment Share on other sites More sharing options...
[To...] Posted March 9, 2022 Share Posted March 9, 2022 Please sign in to view this quote. I love mathisfun. I often used the following to teach people about standard deviation while learning about qualifying styli https://www.mathsisfun.com/data/standard-deviation.html Link to comment Share on other sites More sharing options...
[Re...] Posted March 11, 2022 Share Posted March 11, 2022 I typically let Calypso do the math for me. I would create a secondary alignment with the 20° rotate, then do the section with the secondary alignment using the original vectors. Then change the feature created back to the original alignment and the vectors should be updated. Then I would delete the secondary alignment since it is no longer needed. Link to comment Share on other sites More sharing options...
