Need Vector assistance
For center section, enter X and Y center 0.000. Enter 1.000 in X vector and 0.000 in Y and Z. Make sure expansion is large enough to reach part. Section.
For 20°, enter the COS and SIN of 20° in the X and Y fields. Could be negative value for other side. 0.000 in the Z field.
Make sure X and Y center values are 0.000
Or, create 2 alignments, rotating about Z at 20° and -20°
Then, in the section window, enter X and Y center 0.000 and enter 1.000 in X vector and 0.000 in Y and Z. Make sure expansion is large enough to reach part. Section 1 at Base Alignment. Section 2 at Alignment1 and Section 3 at Alignment2
I cheat and make calypso do the work. I oftentimes create theoretical features in odd alignments and use formulas to derive nominals for real objects. Make a rotated alignment and switch the plane and it will update the new nominals in that orientation. This is helpful in compound angles for cylinders etc..
Thank you both for your responses, but in the end i took the path of least resistance and just copied Tom's numbers.
So in the end i learned nothing and i'm no smarter, but i got another program in the bag.
I have used for many years the Electronics Vest Pocket Reference Book (copy write 1969).
It has among other things, a table of sine's, cosines, and tangents. Very handy.
If you would need it in future, then just use SIN and COS with angle - thats for 2d - for three axis is better to get help from elements 😃
I typically let Calypso do the math for me. I would create a secondary alignment with the 20° rotate, then do the section with the secondary alignment using the original vectors. Then change the feature created back to the original alignment and the vectors should be updated. Then I would delete the secondary alignment since it is no longer needed.
