[Do...] Posted February 3, 2022 Share Posted February 3, 2022 Hello, I’ve measured a small plane with 48 single points and evaluate the flatness with minimum feature. Our client wants to know a partly flatness afterwards (only in the red ellipse, see picture). Is there a possibility in Calypso to analyze only a subpart of the measured points (in this case 30 points instead of 48) ? The product is not available anymore so it’s not possible to remeasure again. I can perform this evaluation for example in Matlab (by using the export point file), but I prefer to do this in Calypso 7.2 Many thanks 🙂 ! Flatness plot.jpgFetching info... Link to comment Share on other sites More sharing options...
[Ma...] Posted February 4, 2022 Share Posted February 4, 2022 Hi, maybe you make a new plane with points recall in the zone that you need. Link to comment Share on other sites More sharing options...
[Er...] Posted February 4, 2022 Share Posted February 4, 2022 If you saved the measured points for the program this should be easy. Copy the feature. Set Recall the feature points. Uncheck the "Re-calculate" button at the bottom. Select the original feature. Right click to "Add Range Limits", select the "New Point Range", enter the first and last points. They may be the first or last 30, so 1 to 30 or 19 to 48. Link to comment Share on other sites More sharing options...
[Do...] Posted February 4, 2022 Author Share Posted February 4, 2022 Hi Erik, Thanks a lot for your solution ! I've tried your way and this work perfect. Exactly what I needed ! Many thanks 🙂 Flatness limit plot.PNGFetching info... Link to comment Share on other sites More sharing options...
[Do...] Posted February 4, 2022 Author Share Posted February 4, 2022 Please sign in to view this quote. Thank you as well Marti ! Link to comment Share on other sites More sharing options...
[Ma...] Posted February 4, 2022 Share Posted February 4, 2022 Welcome, but the solution from Eric will be ther better one 🤣 Link to comment Share on other sites More sharing options...
[To...] Posted February 4, 2022 Share Posted February 4, 2022 Another method for specifying points. Screenshot 2022-02-04 113214.jpgFetching info... Link to comment Share on other sites More sharing options...
[SH...] Posted March 1, 2022 Share Posted March 1, 2022 Please sign in to view this quote. This is same as recall feature points... Link to comment Share on other sites More sharing options...
[To...] Posted March 1, 2022 Share Posted March 1, 2022 Please sign in to view this quote. Yes and no. Recall Feature Points, by default, will recall ALL of the points. This method allows you to select and evaluate only a certain area which is what OP was looking for. Link to comment Share on other sites More sharing options...
